Notices
SOLD...Sonnax LB2 for 45RFE/545RFE...$45
Old Jun 20, 2011 | 04:10 PM
slimvela's Avatar
slimvela
Default SOLD...Sonnax LB2 for 45RFE/545RFE...$45
Have a Sonnax LB2 for sale...
$45 shipped
For those not familiar with what this does...
"This family of transmissions uses a full range line pressure sensor mounted on the
outside of the transmission for "closed loop" line pressure control. Due to this
system, traditional methods of raising line pressure by changing the PR spring or
valves have no effect. The Sonnax Line Pressure Booster alters the pressure signal
sent to the computer causing the computer to raise line pressure. Part number
44957-LB1 (68RFE) has 10-15 psi increase, and 44957-LB2 (45/545RFE) has 15-30 psi
increase. Higher line pressure increases clutch holding power and torque
capacity but with these transmissions, the increase has a limited effect on shift
feel. Changes in shift feel will be noticed mostly under aggressive driving or
loaded conditions. This part is ideal for heavy duty and modified vehicles and
even stock transmissions when a little extra pressure is desired. No other
modifications are required. The Line Pressure Booster installs between the
pressure sensor and vehicle harness using OEM style sealed connectors. Simply
unplug the vehicle harness and reconnect with one of these parts."
Sorry for the cruddy pic, camera lost it's ability to focus properly for some reason...mama, we need a new camera!
Old Jun 21, 2011 | 12:11 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Pictures are required
Old Jun 22, 2011 | 03:21 PM
slimvela's Avatar
slimvela
better-half had to have emergency surgery, sorry for the delay gents...pics are up
Old Jun 24, 2011 | 09:50 AM
jwhirl06's Avatar
jwhirl06
Is it worth the cash, can anyone chime in?
Old Jul 8, 2011 | 05:34 PM
slimvela's Avatar
slimvela
Bump...
Old Jul 8, 2011 | 07:57 PM
Hammond_Egger's Avatar
Hammond_Egger
PM sent.
Old Jul 9, 2011 | 11:18 AM
I love the sonnax. Only really feel it when you are making wot runs. really shifts firm. otherwise you dont notice it. That price is about what they sell for brand new.
Old Jul 10, 2011 | 11:19 PM
slimvela's Avatar
slimvela
That's odd, it made a difference right off the start. Firm shifts all around. A friend felt the same thing as you are describing, but that was due to doing just a plug-n-play and not 'resetting the system' prior to the first drive. But as we all know, every vehicle is different.
New picture to be added to show original packaging/instruction sheet(manual), only had crappy cellphone pic at time of original post.
Old Jul 13, 2011 | 07:18 PM
jwhirl06's Avatar
jwhirl06
Still for sale?
Old Jul 13, 2011 | 11:00 PM
badblackhemi's Avatar
badblackhemi
Just sent the money this afternoon. Sorry man.
