Truck wouldn't start then threw a bunch of codes, can't seem to find much info.
So over the weekend and while out and about went to go start up the truck and got nothing. It had only been off for roughly 30 min while we were inside eating.
Turned everything off, waited a bit, then it started up but I had a CEL. Seemed to run fine so I pulled into an auto parts store to have them pull the codes. What they had were a bunch of communications faults.
So I took it to the dealer, and they wanted $90 just to hook up their computer which I was told over and over does more than just pull codes. Which that's great and all, but all I wanted to know was if its cool to just clear them and watch for them to come back.
I went to go look up the codes myself, and there doesn't seem to be as much information out there as I'm used to with other manufactures.
Network faults:
U110C
U0141
U1403
U110E
U1113
Powertrain:
P30D1
The limited information I could find seemed to indicate possible grounding issue, but I can't get anything from the P30D1.
Any help?
Network faults:
U110C
U0141
U1403
U110E
U1113
Powertrain:
P30D1
Any help?
Found definitions for most of your codes...
U110C- no fuel level bus message
U0141- lost communication w/ front control module
U1403- Implausable fuel level signal
U110E- lost ambient temp message
U1113-LOST A/C PRESSURE MESSAGE
A fella on another forum with the exact error list with a broken tipm bracket (bad ground maybe).
(Big of dodge dtc error codes at https://dodgeforum.com/forum/dodge-c...ber-codes.html )
Unable to find anything for P30D1
As for the codes your truck threw....
P0335-CRANKSHAFT POSITION SENSOR CIRCUIT
P0581-SPEED CONTROL SWITCH 1 CIRCUIT HIGH
P0585-SPEED CONTROL SWITCH 1/2 CORRELATION
P0593-SPEED CONTROL SWITCH 2 CIRCUIT HIGH
Thanks for the info regarding TIPM. Issue only occurred the one time and hasn't come back since. I checked and cleaned terminals, grounding, and checked any wiring I could find. Cleared the codes and will keep an eye on it, but everything been fine.
Fingers crossed.
Fingers crossed.
