Adjusting outer door handle?
The outer door handle on the passenger side of my 2010 Crew Cab Laramie is a little bit "loose".
Not in the sense that it is falling of, but when you are going to open the door it doesn't open/click until it is almost all the way out (and this makes passengers pull really hard in the handle...)
How do I adjust this?
/Jocce
/Jocce
Jocce,
Have you contacted a Dodge dealer to see if they are able to do a quick adjustment? They will have the proper tools to complete the repairs as I believe the bolts to tighten may be located behind the interior door panel and difficult to get at on your own.
Let me know if you have any questions.
Jocce,
/Jocce
/Jocce
EDIT/ADD: your passengers were likely the problem as to why its loose.
These door handles are not rugged, they do break easy if your passengers are heavy handed.
Jocce,
Well that's a little of a curve ball, but if you are looking to complete the repair yourself a service manual can be purchased at www.techauthority.com.
