remote start
All of the following conditions must be met before the engine will remote start:
Shift lever in PARK
Doors closed
Hood closed
HAZARD switch off
BRAKE switch inactive (brake pedal not pressed)
Ignition key removed from ignition switch
Battery at an acceptable charge level
RKE PANIC button not pressed
Fuel meets minimum requirement
System not disabled from previous remote start event
Vehicle theft alarm not active
BUT......Remote start will also cancel if any of the following occur:
If the engine stalls or RPM exceeds 2500
Any engine warning lamps come on
The hood is opened
The hazard switch is pressed
The transmission is moved out of park
The brake pedal is pressed.
Shift lever in PARK
Doors closed
Hood closed
HAZARD switch off
The hood is opened
