Check out the New Ram 2500 / 3500 Vision X Fog Light Kit & Lower Bumper Mount
We've had some pretty high demand for these kits so I wanted to post up this product announcement we just got with some pictures of the new Ram 2500 / 3500 lighting kits from Vision X
Vision X Lighting introduces bright and hassle-free LED lighting kits for 2009.5-2013 Dodge Ram 2500/3500 trucks. Not only do these 3.5” Optimus LED Fog Light kits shine up to 693’ of usable light, they simply bolt-on the stock fog light location and use plug and play connectors with no drilling, no cutting and no wire splicing. Yep that’s right, they plug into the OEM connector, can you say EASY? The Vision X Lighting Dodge Ram 2500/3500 LED Fog light kits are available in a Single kit (2 lights), Dual kit (4 lights) or you can order just the Bracket-Only set.
Complete the lighting upgrade by adding Vision X Lighting’s brightest 21” Xmitter Prime XP LED bar to the Ram’s center bumper slot, by simply bolting it to the all-new Dodge Ram Bumper Light Bar Mount. The center mounted Xmitter Prime XP will provide superior distance with a smooth light pattern and is available in White LED color or Amber LED color for improved vision in fog or dusty conditions. The Vision X Dodge Ram LED Bar mount kit includes the bolt-on bracket, LED light bar and wiring harness. Dodge Ram LED Light Bar bumper mount is also available separately.
Vision X Lighting’s patented, premium LED lights feature an Extended Lifetime Ltd. Warranty to ensure the highest customer satisfaction.
3.5” Optimus Features:
- 693? of Usable Light from 10-watt LED
- 50,000 Hour Lifespan
- 0.83A Draw
- Proprietary IRIS Reflector Technology
- PWM Integrated Dimming Circuitry
- Integrated Electronic Thermal Management (ETM)
- Die-Cast Aluminum Housing
- Polycarbonate lens
- Extended Lifetime Ltd. Warranty
- 21” Xmitter Prime XP Features:
- 5 Watt LED / 17,748 Raw Lumens
- 15.00A Draw
- Aluminum Housing
- XIL-OE0913DR – 9889221 – LED Fog Light Brackets (set)
- XIL-OE0913DROP120 – 9888569 – LED Fog Light Single Kit (Includes Brackets, 2 Optimus Lights and Connectors)
- XIL-OE0913DROP1MX2 – 9889252 – LED Fog Light Single Kit (Includes Brackets, 4 Optimus Lights and Connectors)
- XIL-OEB0913DR – 9889238 – LED Light Bar Bumper Mount
- XIL-OEB0913DRPX3610 – 9889245 – LED Light Bar Bumper Mount w/ 21” Xmitter Prime XP LED Bar w/ Wiring Harness
Why are you not offering a system for 1500 series Rams? I understand the center light would not work because of the different bumper, but 1500 series Ram's have flush mount fog lights too. All that aside, what is the pricing on these kits? Your website does not list any.
The lights seen above are offered as the following kits - MAP Pricing listed, call to order w/ DodgeForum discount, we cannot advertise below MAP.
XIL-OE0913DR – 9889221 – LED Fog Light Brackets (set) - 79
XIL-OE0913DROP120 – 9888569 – LED Fog Light Single Kit (Includes Brackets, 2 Optimus Lights and Connectors) - 309
XIL-OE0913DROP1MX2 – 9889252 – LED Fog Light Mixed Optics Kit (Includes Brackets, 4 Optimus Lights and Connectors) - 549
XIL-OEB0913DR – 9889238 – LED Light Bar Bumper Mount - 69
XIL-OEB0913DRPX3610 – 9889245 – LED Light Bar Bumper Mount w/ 21” Xmitter Prime XP LED Bar w/ Wiring Harness - 1079
And yes, still waiting to hear if your fog light system will work on a 1500 series truck.
Roof mounts are higher demand then fog light mounts for a 1500 series truck? Surprised to hear considering how impractical roof mounted lights are (Only legal off road) as opposed to fog lights which are legal everywhere. I'd day 98% of the Ram's i see on the road have factory fog lights. And even though Rigid has offered a 1500 series roof mount for awhile, I have seen only one on the road.
It varies by region, for sure - but for most truck markets including dodge, Ford, Jeep & Toyota forums, the most requested have been roof bar mounts for the past year or so. It may be different around town, but at every show I go to its "roof mounts, roof mounts, roof mounts"
As far as fitting on the 1500, we have yet to try to test fit it. Physically the lights will fit, but Im thinking the bracket is different. I will do my best to get this confirmed for you all.
