Check Engine Light Code P0933
My truck got the code P0933, i found 2 different descriptions of the code.
1. hydrolic pressure sensor range/performance
2. gear shift lock solenoid ctrl circ/open
I got the enging light on saturday, and since the light has come on when i first start my truck and put it in drive it jumps forward. only happens when i first put it in drive, if i wait 30seconds it doest jum.
Any ideas on what a fix would be/how much it would cost to repair
I have a 2012 ram1500 tradesmen 4wd
P0933-HYDRAULIC PRESSURE SENSOR RANGE/PERFORMANCE
Yep, probably powertrain warranty. Or 8/80K if it's the PCM
Possible Causes
LINE PRESSURE CONNECTOR AND WIRING
INTERNAL TRANSMISSION
POWERTRAIN CONTROL MODULE (PCM)
Possible Causes
