Last edit by: IB Advertising
Browse all: Towing & Hauling Guides
- Dodge Ram 2009-Present: How to Hitch a Fifth Wheel
Step by step intructions for the do-it-yourself repairs.
Short bed 5th wheel advice?
I never used a 5th wheel before, but we want to get a 5th wheel camper. I don't know anyone who has one personally, but I asked a few people at the campsight and they were either 1. clueless, or 2. mentioned something like the B&W RVK3400 or Pullrite Superglide which is about $2000 installed.
I did some searching and found some recommended hitches, but I don't know why it makes sense to spend $1500-2500 on a setup when there are several approximately $500 setups that seem to get good reviews.
I wanted to ask though. Anyone see a problem with just going with a sliding fifth wheel CURT 16516? Amazon has them for $480 with free shipping, plus $65 for the mounting brackets. All the reviews I find online are very good, and I've had great luck with Curt products in the past. I need a slider because I have a short bed.
I read some poor reviews on the cheap Reese hitches, but the Curts only seem to offer glowing reviews. Any thought certainly appreciated.
I know its not good to just go cheap for the sake of being cheap, but it also doesn't make sense to overpay for something!
You are planning on running a 5th wheel on a Ram 1500? What kind of pin weight has that 5th wheel got? Pin weight is typically 20-25% of the total trailer weight, which is why you don't see half tons pulling them.
no problem using a short box, there is many products out there to work for you.
http://www.pullrite.com/products/isr...standard-rails -- I'm using the 16K unit and love it. You don't have to get out and pull the handle it slides back 16 inches as you turn. I tow 7700 lb. 5er -- http://prntscr.com/7expe1 --
Some of the new 5th wheels have the Reese evolution -------
There are options for you and you can convert to one of these pin boxes if the 5th wheel doesn't have one. I got the Pull-rite for half price because no one would buy it,, everyone in this neck of the woods went for the regular slider hitch,, but you forget once, maybe pulling into a tight spot for gas for example and now you have a damage cab. I use Timbren SES suspension http://timbren.com/ in stead of air bags. If you have any other questions I'll try to answer. E trailer are great for advise http://www.etrailer.com/
Yes Curt hitches are a great choice.
Hope some of this helps
Cheers
Happy Rving
Cheers
Happy Rving
Nope, but that makes more sense. Might want to add the 3500 bit to your signature as I'd bet 95% of the folks here have 1500's
