4th Gen Ram Tech2009 - 2018 Rams and the 2019 Ram Classic: This section is for TECHNICAL discussions only, that involve the 2009 - 2018 Rams and the 2019 Ram Classic. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Alright, so my 2011 ram is making a weird grinding sort or sound. Which seems to be coming from the end of the drive shaft where it meets the differential. Also, when the truck is in drive with foot on brake, when you slowly take your foot off the brake the truck "hops" at first? Then stops completely once RPMS reach above 1k. Please help. I'm lost
Sounds potentially catastrophic. You do NOT want to lose a rear end or driveshaft while going down the road. I would have it towed to your dealer and have them diagnose.
Either get under there and check out the driveshaft at the diff end or have someone do it for you. I've lost a driveshaft before (ironically on my first car which was a 72 Dodge Coronet!) and at speed......it can be devastating.
