LIGHTNING AUDIO POWER/GROUND WIRE, DISTRIBUTION BLOCKS, BATTERY CLAMPS & MORE
FOR SALE : POWER/GROUND WIRE, DISTRIBUTION BLOCKS, BATTERY CLAMPS, MONSTER CABLE, AND MORE. TOP OF THE LINE BRANDS WHICH INCLUDE LIGHTNING AUDIO, MONSTER CABLE, MTX THUNDERSTUFF, AND MOBILE SPEC. ALL ITEMS ARE UNUSED. IF INTERESTED, I CAN EMAIL PICTURES. I WAS UNABLE TO UPLOAD PICTURES WITH THIS POST.
2 BLUE SPOOLS OF LIGHTNING AUDIO LIGHTNING STRIKE 1/0 AWG OPTIMUM PERFORMANCE POWER/GROUND WIRE 1029 STRANDS FOR PEAK CURRENT TRANSER-25 FT EACH. ONE OF THE PLASTIC ENDS IS BROKEN OFF, NO DAMAGE TO THE WIRE AT ALL.
E
1 BLUE SPOOL OF LIGHTNING AUDIO LIGHTNING STRIKE 4AWG OPTIMUM PERFORMANCE POWER/GROUND WIRE-413 STRANDS FOR PEAK CURRENT TRANSFER-100 FT
1 SILVER SPOOL OF LIGHTNING AUDIO LIGHTNING STRIKE 1/0 AWG OPTIMUM PERFORMANCE POWER/GROUND WIRE 1029 STRANDS FOR PEAK CURRENT TRANSFER-25 FT.
1 SILVER SPOOL OF LIGHTNING AUDIO LIGHTNING STRIKE 4AWG OPTIMUM PERFORMANCE POWER/GROUND WIRE-413 STRANDS FOR PEAK CURRENT TRANSFER-100FT.
3 LIGHTNING AUDIO STORM ACID PLATINUM MPD BATTERY CLAMPS-MULTI OUTPUT (2) 1/0AWG NEGATIVE
3 LIGHTNING AUDIO STORM ACID PLATINUM MPD BATTERY CLAMPS-MULTI OUTPUT (20 1/0AWG POSITIVE
2 LIGHTNING AUDIO STRIKE GOLD PLATED AGU FUSED DISTRIBUTION BLOCK-4AWG INPUTS/8AWG OUTPUTS-2 POSITION
2 LIGHTNING AUDIO STRIKE GROUND DISTRIBUTION BLOCK-2 1/OAWG INPUTS/3 4AWG OUTPUTS
2 LIGHTNING AUDIO STRIKE GOLD PLATED AGU FUSED DISTRIBUTION BLOCK-4AWG INPUTS/8AWG OUTPUTS-4 POSITION
1 LIGHTNING AUDIO STRIKE GOLD PLATED ANL INLINE FUSE HOLDER-ACCEPTS 1/0 OR 2AWG WIRE
LIGHTNING AUDIO HIGH PERFORMANCE BUSS BAR CONNECTORS
2 MONSTER CABLE-MONSTER CAR POWER-CRIMPLESS POWER RING TERMINALS-CABLE SIZE GAUGE 1/0. DESIGNED FOR EASY CONNECTION OF 1/0. 4 AND 8 GAUGE POWER CABLES TO AMPS & BATTERIES, 24K GOLD PLATED FOR HIGHER CONDUCTIVITY AND CORRROSION RESISTANCE, ACCEPTS 5/16" STUDS
2 MONSTER CABLE-MONSTER CAR POWER-CRIMP TYPE POWER RING TERMINALS-CALBE SIZE (GAUGE) 1/0-STUD OPENING 3/8", 100% WATERPROOF CONNECTION WHEN COVERED WITH MELTLINER HEAT SHRINK (PROVIDED), 24K GOLD PLATED FOR HIGHER CONDUCTIVITY AND CORROSION RESISTANCE.
6 MOBILE SPEC ELCTRONIC ACCESSORIES-POWER WIRE ADAPTER FOR 1/0 GA. TO 4 GA. PERFORMANCE SERIES.-POWER WIRE ADAPTER FOR 1/0 GA. TO 4 GA. , 24K GOLD PLATED FOR HIGHER CONDUCTIVITY.
1 MTX THUNDERSTUFF RCA CONNECTORS-YB2FC
ALL ITEMS ARE RETAIL VALUED OVER $350. ASKING $250/OR BEST OFFER PLUS SHIPPING COSTS. IF INTERESTED SEND EMAIL TO MYCANDLEOFTHOUGHT@HOTMAIL.COM.
E
