Lug Nut Measurements To Fit Center Caps?
Old Apr 9, 2019 | 05:25 PM
cray54's Avatar
cray54
Default Lug Nut Measurements To Fit Center Caps?
I'm looking for the measurements on a M14x1.5 OEM stock lug nut that correctly fits the center caps that clip over them. Specifically: the overall height, the widest diameter of the seat, and the hex size.
Can someone with access to these check the measurements? [My lugs are not correct, so the center caps don't clip on.]
Otherwise, I'd be interested in a recommendation for a decent priced / decent quality set on Amazon or otherwise that is known to fit right.
Thank you, Chris
Old Apr 19, 2019 | 11:31 PM
cray54's Avatar
cray54
I ended up finding a used set of OEM lug nuts by asking sellers with wheel sets if they also had lug sets. If you are in need of the lug nuts that fit center caps on a Gen 4 truck (M14x1.5 thread)… definitely try to find a used set. It is the best way to find a set that works with the center caps and has a reasonable price. The dealer wanted $6 each, the local auto stores didn't have the right size to work with the center caps.
If anyone needs the measurements:
Overall Height: 25.7mm
Bulge Diameter: 29.3mm
Hex Size: 22mm
