Notices
TRADE: Nav Radio and Factory Uconnect parts for Home Theater PC
Old Apr 21, 2006 | 04:05 AM
rcompart's Avatar
rcompart
Default TRADE: Nav Radio and Factory Uconnect parts for Home Theater PC
I just bought a new Caliber and it didn't come with these options so I'm looking to add them.
What I need is the Nav unit(82208653AE) with the DVD and GPS Antenna, the dash bezel in silver(YZ081Z2AB), the Uconnect Mirror(4806228AB), Uconnect Telemarics unit(5064013AV), and the Uconnect/Auto Dimming mirror harness(5089-051AB) and if you can find them, the steering wheel radio controls.
Here is the specs on the home theater PC. All of this would cost around $1600 to give you an idea
Case:
Silver Ahanix X235 D5 Media Center Enclosure
Power Supply:
Athena Power AP-MP4ATX45 MicroATX 450W Power Supply
Motherboard:
Abit GD8 Pro LGA775/915P/DDR2/SATA/A&L/ATX
Processor:
Intel Pentium 4 516 2.93GHz 533MHz 1MB EM64T LGA775
CPU HS/Fan:
Zalman CNPS7000B-CU P4 & AMD Quiet CPU Cooler
Cooling Device:
Socket 775 CPU Installation Clip for 7000 Series (ZM-CS1)
Memory:
Kingston HyperX 1GB (2 x 512MB) 240-Pin DDR2 SDRAM Unbuffered DDR2 533
Video Card:
ASUS Radeon AX550PRO 256MB 128-bit GDDR2 PCI Express x16
Cooling Device:
Zalman ZM80D-HP Fanless Heatpipe VGA Cooler
Network Card:
US Robotics USR5417 Wireless MAXg PCI Adapter
Optical Drive:
Samsung 16X DVD±R DVD Burner Black Model SH-W162Z / BEBN
Keyboard/Mouse:
Adesso 2.4GHz RF Wireless Mini USB Keyboard
Hard Drive:
Samsung SpinPoint P HD080HJ 80GB 7200 8MB SATA 3Gb/s
Hard Drive:
3 Samsung SpinPoint P SP2504C 250GB 7200 8MB SATA 3Gb/s
TV Tuner Card:
Hauppauge WinTV-PVR 500 MCE Dual TV Tuner & FM Radio
Cooling Device:
3 Vantec Stealth 6cm Double Ball Bearing Silence Case Fan, 20dbA
Cooling Device:
Zalman Fan Mate 2 / Adjustable Fan Speed Connector 3-pin
As you can see, I have put a lot of money into this Home Theater PC. It is top notch all the way around with components that were chosen for high performance and low noise. Everything about this is awesome. Watch TV on one channel and record on another. Listen to all your music and create playlists that you can enjoy for hours or even days without having to change CDs. View all your home videos without complicated VCRs. Listen the FM radio while you do chores around the house. Get local weather forcasts and news delivered to your TV 24 hours a day. Record your picture albums to CD or DVD and take them anywhere. Save the movies you watch often and never have to search for that DVD again or worry about it getting scratched. With this Home Theater PC, you can do all that and more. It is a full fledged computer too, so if you want to, you can use MS Office, play you favorite computer games, check email, surf the internet or instant message friends and family from your recliner with the keyboard/touchpad combo. This thing is a real beauty as well. With the brushed aluminum case, it will blend right in with your other equipment. As for all the technical stuff; It has one DVI, one VGA and one S-Video output, 7.1 channel optical S/PDIF and analog 3.5mm phono surround sound outputs, two S-Video inputs, two composite(yellow RCA connector) video inputs, two stereo RCA inputs, two tuner inputs(one for TV and one for FM radio), five external USB ports, Gigabit RJ-45 LAN connector, PS/2 keyboard and mouse ports and a serial port. It also has a parallel port but it is occupied by the LCD cable. It has 750GBs of storage for movies, TV, pictures and DVDs. It also has an 80GB drive dedicated to the operating system, and programs. Both of these drives are whisper quiet adn the only time you should ever hear them is when you start it up. I replaced the power supply with a higher wattage one to keep everything operating at peak performance with no voltage sags or spikes. The heatsink for the videocard replaces the fan that was on there to keep everything as quiet as possible. You will notice that it does not include an operating system since people prefer different front ends. You can get all these features with Windows XP Home, Pro, Media Center Edition. With XP Home and Pro, you can use software such as SageTV, Meedio, SnapStream or Media Portal.
