Notices
FS: '92 Dakota Club Cab LE
Old Jul 7, 2006 | 02:33 AM
fueloil's Avatar
fueloil
Default FS: '92 Dakota Club Cab LE
For Sale: 1992 Dodge Dakota Club Cab LE.
3.9 V6 Magnum 180HP engine, Automatic Overdrive Transmission. Truck is loaded with power windows, power door locks, tilt wheel, cruise control, Cold A/C. Velour seats, Carpet, sliding back glass, Code alarm, factory cassette stereo, with upgraded speakers. Black steel spoke wheels. Bed liner. Truck is burgundy, with red interior. 133k. I’m the second owner. I’ve owned it for 12 years. It has had Mobil 1 synthetic oil since it’s 15K oil change. Trans fluid and rear differential fluid (Mobil 1 synthetic gear lube) changed every 30K. Truck has been well maintained. New parts replaced in the last year: Water pump, hoses, belt. Idle control motor. Power steering pump. Major tune up with plugs, wires, distributor cap and rotor. Driveshaft rebuilt with new U-joints and carrier bearing. Front shocks, dual exhaust. Transmission rear seal. Brakes (all 4 wheels) and master cylinder. A/C Compressor, and drier. Windshield.
Truck has fresh plates, and inspection sticker. (07/07 on both)
The truck runs and drives great. It uses no oil, and has no fluid leaks. I wouldn’t hesitate to drive it anywhere.
Things the truck needs:
Headliner. The original headliner started to “Droop”, so I took it out.
Truck needs paint. I had it painted about 8 years ago. It needs it again.
Tires are at about 50%. It will need new shoes before long.
Well, there it is. The truck is in West Houston. I’m selling it, because I have another truck, and I just don’t drive this one much anymore. It will make someone a nice dependable ride.
$2800.00
Paladin_jim@hotmail.com
