Notices
04 srt4 parts for sale - aftermarket and stock
Old Sep 23, 2006 | 07:04 PM
posthondaremoval's Avatar
posthondaremoval
Default 04 srt4 parts for sale - aftermarket and stock
Hey all - I have some parts left for sale. will ship if necessary.
Make offers on anything u r interested in...i'll talk nimbers:
-Lorenzo tb (60 mm with spacer and gasket - in good shape - works perfectly. - $275
-mopar bov - obviously like new; they aren't a wear item - 35 local or 40 shipped
-stage 0 wastegate - only on car for 3000 miles so like new. - 35$ local or 40 shipped - never seen a price - is this fair?
-fuel injector cover - looks great - $30 local or 40 shipped
-DC rear stb - like new - 70$ local - ? shipped
-rear tension struts - new in box 40 local - ? shipped
-stoptech ss front brake lines - new in package - but 75$ local or 85$ shipped
-stock plastic grills - like new - 25$ local or 30 shipped
-Kicker livin loud audio system with tags and sticker still in package - great condition - Sub and amp combo - make offers - hardly used(never listened to music much in the car) 250 obo
- 6 cd add on changer - Make offers - 75 obo
-floormats - 3 in perfect condition drivers has some heal wear under gas pedal area - 60 or make offers
-greddy oil catch can - new in box - $70 locally - 80 shipped
-stant thermostat - 180 degree - new in box - 12 locally, 17 shipped
-turn signal and lights stalk assembly - like new - with fog ramp shaved and ready for conversion if you are looking to do the fog light mod.(yhou just need a couple relays and a little wire and a fuse. - 40$ locally - ? shipped
-clear 3rd brake light and clear led bulb that lights red for it - $25 local or 30 shipped
-2 homemade catch cans (campbell hausfield type) - 8$ each local - 10$ each shipped - specify black or blue
-HKS 6 wire gold plated clamp on negative terminal for mutiple grounds out of battery - new in box - 20$local - 30 shipped
-stock side marker lenses and bulbs - $15 locally 22 shipped
-msd spark plug wires - red - used for 9,000 miles - still work perfectly - 35 locally - 40 shipped
-10 mm custom high temp shielded red spark plug wires from sparkplugs. com - used for 6000 miles and work perfectly - 45 locally - 50 shipped
-Motegi Traklites in polished graphite - 13.5 lbs per wheel! perfect condition with toyo proxes T1-S 225-45-17 with a bit of tread left (run for about 6-7000 miles) - Only have 3 - one was crushed in accident - I can hook you up with a cheap reliable source for the fourth wheel if you need. - 850 locally - ? shipped
-stock wheel in good condition with a bridgestone blizzak lm-25 winter tire - Just 1 wheel - make offers
-srt-4 polo shirt in black - never worn - 15 locally - 20 shipped
-srt-4 clock with silver srt-4 picture - 15 locally, 20 shipped
-numerous srt-4 models - a few in both - diecast in 1:24 scale and matchbox xize - still in boxes - inquire on which you want and well set price since there are a number of different ones
-a srt-4 mini remote control car - new in package - like zip zaps - 25 locally - 30 shipped
Thats all i am getting off memory - if there is more - I'll post up.
SOLD - S2 wga
SOLD - s2 kit w/toys
SOLD. EDIT - I knew there would be more - I also have a Maxxfab downpipe assembly for sale. the flex joint may be a little crushed so i dont know if it needs to be replaced for ift(it is a separate bolt on piece so it can be replaced pretty cheaply. - It is the 3" dp with interchangeable cat and test pipe so you can go catless or not - whichever you like - the race cat has never been used. It is set up to slip fit to a 2.5 inch exhaust like the borla. - make offers
SOLD. I also have the borla exhaust - the tips have a flatspot about 6 inches in from the tip from the accident - it could be pushed out probably but is not visible while on the car. - make offers
Thanks for your interest
Adam
