intrepid 2002 2.7l
I own a 2002 intrepid 2.7 L when get at an intersection and take off it sounds like the engine stops firing at the plugs and car move very slowly then kicks in after 10 or 15 seconds what would cause that engine codes are p0452,p0300,po351,p0132,p0138,p0056,p0141https://dodgeforum.com/micons/m15.gifhttps://dodgeforum.com/micons/m12.gif
RE: intrepid 2002 2.7l
Codes:
P0452 Generic Evaporative Emission System Pressure Sensor/Switch Low Input P0300 Generic Random Misfire Detected P0351 Generic Ignition Coil A Primary/Secondary Circuit P0132 Generic O2 Circuit High Voltage (Bank 1, Sensor 1) P0138 Generic O2 Circuit High Voltage (Bank 1, Sensor 2) P0056 Generic HO2S Heater Control Circuit (Bank 2, Sensor 2) P0141 Generic O2 Heater Circuit (Bank 1, Sensor 2) Research the first code (the switch) When was the last time you change your O2 sensors. I have a complete Dodge Intrepid manual to download if you like. The manual is not Haynes or Chilton. I had the one code p0141 and had to replace my PCM at the dealer. |
changed o2 bank 1 sensor 1 about 1 year ago how would i check p0452 wich is evaporative emmision system pressure sensor/switch low input
can someone tell me how to test a Evaporative Emission System Pressure Sensor/Switch Low Input
P0452 code |
This taken from manual NATURAL VAC LEAK DETECTION ASSY DESCRIPTION The natural Vacuum Leak detection (NVLD) system is mounted on top of the EVAP canister (Fig. 3) that is mounted on the fuel tank. OPERATION The Natural Vacuum Leak Detection (NVLD) system is the next generation evaporative leak detection system that will first be used on vehicles equipped with the Next Generation Controller (NGC) starting in 2002 M.Y. This new system replaces the leak detection pump as the method of evaporative system leak detection. This is to detect a leak equivalent to a 0.020 9 (0.5 mm) hole. This system has the capability to detect holes of this size very dependably. The basic leak detection theory employed with NVLD is the [font="times new roman"]39[font="times new roman"]40Gas Law4344. This is to say that the pressure in a sealed vessel will change if the temperature of the gas in the vessel changes. The vessel will only see this effect if it is indeed sealed. Even small leaks will allow the pressure in the vessel to come to equilibrium with the ambient pressure. In addition to the detection of very small leaks, this system has the capability of detecting medium as well as large evaporative system leaks. A vent valve seals the canister vent during engine off conditions. If the vapor system has a leak of less than the failure threshold, the evaporative system will be pulled into a vacuum, either due to the cool down from operating temperature or diurnal ambient temperature cycling. The diurnal effect is considered one of the primary contributors to the leak determination by this diagnostic. When the vacuum in the system exceeds about 1 9 H2O (0.25 KPA), a vacuum switch closes. The switch closure sends a signal to the NGC. The NGC, via appropriate logic strategies (described below), utilizes the switch signal, or lack thereof, to make a determination of whether a leak is present. Fig. 2 UPSTREAM HEATED OXYGEN SENSOR 1/1 1 - PROPORTIONAL PURGE SOLENOID 2 - O2 SENSOR Fig. 3 NVLD ASSEMBLY LH EVAPORATIVE EMISSIONS 25 - 13 EVAP/PURGE SOLENOID (Continued) The NVLD device is designed with a normally open vacuum switch, a normally closed solenoid, and a seal, which is actuated by both the solenoid and a diaphragm. The NVLD is located on the atmospheric vent side of the canister. The NVLD assembly may be mounted on top of the canister outlet, or in-line between the canister and atmospheric vent filter. The normally open vacuum switch will close with about 1 137[font="times new roman"]138 H2O (0.25 KPA) vacuum in the evaporative system. The diaphragm actuates the switch. This is above the opening point of the fuel inlet check valve in the fill tube so cap off leaks can be detected. Submerged fill systems must have recirculation lines that do not have the in-line normally closed check valve that protects the system from failed nozzle liquid ingestion, in order to detect cap off conditions. The normally closed valve in the NVLD is intended to maintain the seal on the evaporative system during the engine off condition. If vacuum in the evaporative system exceeds 3 9 to 69 H2O (0.75 to 1.5 KPA), the valve will be pulled off the seat, opening the seal. This will protect the system from excessive vacuum as well as allowing sufficient purge flow in the event that the solenoid was to become inoperative. The solenoid actuates the valve to unseal the canister vent while the engine is running. It also will be used to close the vent during the medium and large leak tests and during the purge flow check. This solenoid requires initial 1.5 amps of current to pull the valve open but after 100 ms. will be duty cycled down to an average of about 150 mA for the remainder of the drive cycle. Another feature in the device is a diaphragm that will open the seal in the NVLD with pressure in the evaporative system. The device will [font="times new roman"]209210blow off9 at about 0.5 9 H2O (0.12 KPA) pressure to permit the venting of vapors during refueling. An added benefit to this is that it will also allow the tank to [font="times new roman"]233234breathe9 during increasing temperatures, thus limiting the pressure in the tank to this low level. This is beneficial because the induced vacuum during a subsequent declining temperature will achieve the switch closed (pass threshold) sooner than if the tank had to decay from a built up pressure. The device itself has 3 wires: Switch sense, solenoid driver and ground. It also includes a resistor to protect the switch from a short to battery or a short to ground. The NGC utilizes a high-side driver to energize and duty-cycle the solenoid. REMOVAL (1) Disconnect the negative battery cable. (2) Remove fuel tank, refer to the Fuel Delivery section for Fuel Tank Removal. (3) Disconnect the electrical connector from the NVLD assembly. (4) Disconnect the hoses from the NVLD assembly (Fig. 5). (5) Lift tab on NVLD assembly (Fig. 4) and twist the assembly counterclockwise and pull up to remove from EVAP canister (Fig. 5). (6) Remove O-ring from EVAP canister (Fig. 6). INSTALLATION (1) Install O-ring to EVAP canister (Fig. 6). (2) Install NVLD assembly (Fig. 4) and twist the assembly clockwise to lock assembly in the EVAP canister (Fig. 5). (3) Connect the hoses to the NVLD assembly. (4) Connect the electrical connector to the NVLD assembly. Fig. 4 LOCKING TAB Fig. 5 ASSEMBLY REMOVED 25 - 14 EVAPORATIVE EMISSIONS LH NATURAL VAC LEAK DETECTION ASSY (Continued) (5) Install fuel tank, refer to the Fuel Delivery section for Fuel Tank Installation. (6) Connect the negative battery cable. ORVR DESCRIPTION Onboard Refueling Vapor Recovery (ORVR) System Schematic and components. OPERATION The emission control principle used in the ORVR system is that the fuel flowing into the filler tube (approx. 1” I.D.) creates an aspiration effect which draws air into the fill tube (Fig. 7). During refueling, the fuel tank is vented to the vapor canister to capture escaping vapors. With air flowing into the filler tube, there are no fuel vapors escaping to the atmosphere. Once the refueling vapors are captured by the canister, the vehicle’s computer controlled purge system draws vapor out of the canister for the engine to burn. The vapors flow is metered by the purge solenoid so that there is no or minimal impact on driveability or tailpipe emissions. As fuel starts to flow through the fill tube, it opens the normally closed check valve and enters the fuel tank. Vapor or air is expelled from the tank through the control valve to the vapor canister. Vapor is absorbed in the canister until vapor flow in the lines stops, either following shut-off or by having the fuel level in the tank rise high enough to close the control valve. The control valve contains a float that rises to seal the large diameter vent path to the canister. At this point in the fueling of the vehicle, the tank pressure increase, the check valve closes (preventing tank fuel from spiting back at the operator), and fuel then rises up the filler tube to shut-off the dispensing nozzle. If the engine is shut-off while the On-Board diagnostics test is running, low level tank pressure can be trapped in the fuel tank and fuel can not be added to the tank until the pressure is relieved. This is due to the leak detection pump closing the vapor outlet from the top of the tank and the one-way check valve not allowing the tank to vent through the fill tube to atmosphere. Therefore, when fuel is added, it will back-up in the fill tube and shut off the dispensing nozzle. The pressure can be eliminated in two ways: 1. Vehicle purge must be activated and for a long enough period to eliminate the pressure. 2. Removing the fuel cap and allowing enough time for the system to vent thru the recirulation tube. |
