Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
2010 Dodge Journey Chinese Display
Old 01-22-2011, 03:14 PM
taiwanese's Avatar
taiwanese
taiwanese is offline
Default 2010 Dodge Journey Chinese Display
Does anyone know how to display chinese mp3 file names in HDD?
Old 01-23-2011, 01:45 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Welcome to DF
I don't know which system you have, But here is a way to change the display. This is out of the owner manual. If this doesn't work, post the radio that you have.
GETTING STARTED
NOTE: The ignition switch must be in the ON or ACC
position to operate the radio.
If the unit is OFF, switch it ON by pushing the ON/OFF
VOLUME rotary ****.
Change the Language
The radio will conform to the vehicle language set in the
ELECTRONIC VEHICLE INFORMATION CENTER
(EVIC), if equipped.
If you change the language in the radio, the vehicle will
change the language for all display information. Refer to
the vehicles Owner’s Manual.
To change the language with the radio:
1. Press the MENU hard-key on the right side of the
radio.
2. Then press the System Setup soft-key to get to the
System Setup menu.
3. Press the Language soft-key and select a language.
Set the Time
1. Press the Time soft-key in the lower left corner of the
screen.
Old 01-24-2011, 10:36 AM
taiwanese's Avatar
taiwanese
Hi,
Thanks for the info, but the language setting only contains English, French or Spanish.
The radio I have is the one without touchscreen and with navigation. It has a turn **** for controls and not the touchscreen.
I'm not sure where to find the radio information.
My file name with Chinese is displaying weird characters. I wonder if I can install chinese support.
Old 01-24-2011, 10:36 PM
master tech
Sorry i don't know, if you can install any software support. Do you know what radio that you have? REN or REU
Old 01-31-2011, 10:58 PM
taiwanese's Avatar
taiwanese
It's REU.
What I am trying to do is to display chinese filenames in MyGig. Don't know if this is possible?
Old 04-28-2011, 08:24 AM
bloom08's Avatar
bloom08
bloom08 is offline
u can go through the users manual properly and see if there is any such options. sometimes u get these options but then it is region dependent.
Quick Reply: 2010 Dodge Journey Chinese Display
