2009 Dodge Journey power window problem - DodgeForum.com
Go Back  DodgeForum.com > Dodge Vans & CUVs > Dodge Journey
Reload this Page > 2009 Dodge Journey power window problem
Dodge Journey Dodge Journey forum for discussion on the popular Dodge Crossover and CUV.
Old 11-16-2017, 08:43 AM
mooresae
mooresae is offline
Default 2009 Dodge Journey power window problem
Hi, I'm new to the forum so here's a problem I need help with. I have a 2009 Dodge Journey and am having a problem with the drivers side power window with the one touch system. It's almost all of the way down and won't go up or down. When you push the button, you hear a click in the door and the motor barely moves. Removing the motor from the regulator it still does the same thing. I scanned the system and got the following code:
B1855 Driver Window Control Circuit High
B1d34 Driver Mirror Heater Control Circuit High
B2578 Driver Window Not Calibrated/Lost calibration
Can any one tell me what these codes mean, likely causes, most likely fix?
Thanks
Old 11-16-2017, 08:50 AM
jkeaton is offline
Site Moderator
Have you had the door wiring recall done?
Old 11-16-2017, 08:58 AM
mooresae
mooresae is offline
I/m not sure if it has been done or not. This is a customers vehicle and I don't think they've owned since it was new. Would the dealer be able to tell be by giving them the vin number? Thanks
Old 11-16-2017, 09:04 AM
jkeaton is offline
Site Moderator
So, you are a repair shop? lol.....Yes. The dealer would know.
Old 11-16-2017, 09:10 AM
mooresae
mooresae is offline
Yes we are a repair shop. We deal with all types of electrical problems on all types of vehicles. From car and trucks to construction equipment. Before I spent a lot of time on this I thought I would hit the forum to see if any one has had the same issue. Do you know what the codes mean?
Old 11-16-2017, 09:17 AM
jkeaton is offline
Site Moderator
B1855: http://www.obd-data.com/b1855.html
B1D34: http://www.obd-data.com/b1d34.html
B2578: http://www.obd-data.com/b2578.html
Still check for the door wiring recall. Known to cause all kinds of electrical issues. That's where I would definitely start.
Old 11-16-2017, 11:54 AM
TNtech's Avatar
TNtech
TNtech is offline
Site Moderator-Dodge Tech
Dodge Forum Moderator
If you're going to work on people's cars, you seriously need to consider subbing to an online database such as Identifix. I particularly like this one because people contribute fixes for certain conditions to the database. It doesn't always get your answer, I know. I have fixed several cars with GOOGLE before...as pathetic as that sounds coming from a dealer tech with all of their resources LOL
HIGH DTCs almost always indicate an open circuit.
Old 11-16-2017, 12:48 PM
mooresae
mooresae is offline
We're are going to start using Identifix for sure but don't have it available at this time. I disconnected battery due to it being weak and replacing it. When I connected it back up, everything started working again. Cleared the codes and rescanned the system and no codes show up now. This vehicle wasn't one that was recalled due to the wiring problem with the door harness
Old 11-16-2017, 12:52 PM
jkeaton is offline
Site Moderator
Good to hear. Yep, weak batteries cause all sorts of weird electrical issues on newer cars.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Featured Sponsors
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
