5.7 RT - weird miss
Old 06-23-2017, 08:22 PM
Porsch964's Avatar
Porsch964
Porsch964 is offline
Default 5.7 RT - weird miss
2005 Magnum RT , 133k
Last two days, when driving I feel weird hesitation. I don't know what it is. Almost feels like hitting a rev limiter and not a transmission issue. The tranny has about 74k miles on it.
No fault codes. No dash lights and the issue seems to happen in any gear. I'm about 14k over on needing a tranny flush.
Plugs replaced 74k miles ago when I got a fault code.
Really hard to describe. Hope the fault code shows itself someday.
Thanks for any help.
Old 06-24-2017, 12:26 AM
HemiLonestar's Avatar
HemiLonestar
HemiLonestar is offline
Does it shake and/or hesitate, not want to rev right or run smooth?
Old 06-24-2017, 06:54 AM
Porsch964's Avatar
Porsch964
It happens so quickly I don't even notice the rpms jump. It's a quick hesitation when applying the gas in any gear (tried to see a difference with auto stick). My son in the back seat asked me what was that.
Maybe I could video the event with some help.
Old 06-24-2017, 09:42 AM
Porsch964's Avatar
Porsch964
Video doesn't show much.
Old 06-25-2017, 12:45 PM
Porsch964's Avatar
Porsch964
The car posted two codes.
CPS sensor and a miss fire. Hmmm
Looks easy enough to replace but is it actually the problem? I don't have starting issues.
Thoughts?
Old 06-25-2017, 12:47 PM
Porsch964's Avatar
Porsch964
Old 06-26-2017, 03:04 PM
HemiLonestar
Actually yes, in fact the misfire may have been cause by the crank sensor. Start with the crank sensor, clear the codes then see if the misfire is still there. If it is, then you either have a coil going or one or both of the plugs in that cylinder are done. If the CPS doesn't clear the misfire, swap the coil with another one to see if the problem migrates.
Old 06-26-2017, 10:03 PM
Porsch964's Avatar
Porsch964
Thanks. Just bought the last CPS in Indy. Supposedly the part is on back order.
PB sprayed the bolts and will pu the part on Tuesday.
Old 07-06-2017, 06:47 PM
Porsch964's Avatar
Porsch964
Replaced CPS sensor. Pretty easy job except for removing the connector.
Connector had lock and a squeeze and pull connector.
Note.
Unlock, if hard to move use contact spray.
Squeeze rocker end then pull connect from the opposite side.
Problem was resolved. Thanks
