Dodge MagnumThe Dodge Magnum, the wagon that made wagons cool. The unique look of the Dodge Magnum makes any trim level, from SE to SRT-8, an absolute head turner.
Use tool to unscrew nut. Use ball joint tool to separate from spindle. If you're removing the whole tension strut you'll need to undo the large bolt and nut and the other end.
