severe wheel / tire wobble
Hi I have an 07 dodge magnum rt rwd police edition and when i go over 60 mph there is a shake in the front end like the tires seem to be out of balance. Also when i brake hard or turn to the left the driver side tire seems to go into an uncontrollable wobble until i slow down and go below 55 mph. i checked the tires (haven't balanced them) they have been on the car since i purchased it. and i also replaced the front rotors and pads but that didn't seem to fix the problem. any help on what would make the driver side wheel go into an uncontrollable wobble will be greatly appreciated!
if it was front wheel shake it would transmit into the steering wheel; do you have a steering wheel shimmey?
the weird thing is no wheel shimmey its like just on the driver side tire/wheel like an uncontrollable wobble until i slow down. like the turn makes something come loose.
any ideas?
vibrations at hwy speed from the front on a rwd car....rule out the tires first.
stuff you could check yourself -raise the front end on jackstands and spin the tires by hand...look for tire and wheel runout....wobbles, out of round tires from broken belts in the tire -check for worn suspension parts...ball joints, tie rod ends, loose wheel bearings, strut rods that locate the control arm/knuckle -rotate the tires and see if the problem moves with the tires -if you have winter tires, install them to help rule out tire problems or have a shop test drive and diagnose it. |
