starter fuse 5a? What is it for?
Car will not start or crank. I put key in
ingnition, all lights come on but after 10 seconds console light go away and won't come back until you wait for a bit. Checked fuses and swapped relays, no effect. Swapped the computer system out to test. No effect. Battery is good. Starter will crank if I jump the relay. Won't even stay on long enough to run a scanner. Everything electric works. Locks, windows, radio, etc. Only think I can find is that the 5a starter fuse does not have any power. |
How have you verified the battery is good? |
Thanks for replying.
12.5 v and I put a different more powerful battery in just to double check. I will post a video of what the car is doing. |
