Dodge MagnumThe Dodge Magnum, the wagon that made wagons cool. The unique look of the Dodge Magnum makes any trim level, from SE to SRT-8, an absolute head turner.
It will always upshift when it hits the upper rpm range. Safety feature to keep you from causing damage to the engine or trans. If the rpm's stay low enough it should stay in gear.
yeah, what ^^^^^ said. you can change the autostick features with a flashpaq. i have mine set on paddle hold. it will not shift until you bump the stick.
The Superchips flashpaq tuner has options to enhanced shifting with the reduction of torque management, adjust shift points & rev limiter, select Autostick shifting with gear hold, eliminate the speed limiter and recalibrate the speedometer for replacement tire sizes 17" to 37". You can also choose between 87 octane and 91 octane performance tunes. The tuner is internet updateable and can be used to read diagnostic trouble codes. Like Hypertech but with more options.
