Will SRT8 wheels fit the R/T AWD?
I need an answer to this question. I know the offset is greater on both the AWD and the SRT8 but is it a match?[&:]
RE: Will SRT8 wheels fit the R/T AWD?
yes, the bolt pattern is a match and they will bolt on. will they stick out of the wheel wells some, yes....
Fabulous. Thanks Standard65. Now to how much they will stick out.
Anyone seen a picture with SRT8 weels mounted on an AWD? :D |
there is about a 40mm difference in offset between the two wheels and the srt wheels are 1.5 wider.
let's see, 40mm is about 1.5" plus half of the width difference is .75", and the total difference is 2.25" so, i would guess about 2 1/4" more than your wheels are now. |
No they will not work. I put a set of regular Rt rims on my AWD and it stuck out from the wheel well about and 1 inch. So i dont think the SRT rim will work due to the back spacing. NO No .
they will bolt on just fine.
they will stick out 2 1/4" more that original. he didn't ask if it looked good. maybe, he's looking for the 4 X 4 look to complete the AWD he has. it's not my style, but a lot of people like the wheels sticking out some. |
I thought there was a pretty big offset on the AWD wheels as well. I assume the bolt pattern is the same. I don't these things sticking out 2.5"
they won't stick out 2.5" they will only be 2 1/4" more than where you are now. they may stick out 1/2" to 3/4"
find someone with a srt and see if you can test the fit a wheel. |
Well i tried a set of RT rims on my car and they stuck out pretty good about an inch and a half. so the SRT rims will do that a little bit more. Yes they will bolt up fine . I love those rims and would love to put them on my cart but just would not look right sticking out that far. It would look like an off road truck.
65Standard. I thought the AWD wheels had a 50mm offset. What is the offset for the SRT8 wheels? It would be great to borrow a SRT8 wheel but that is probably easier said than done.. I dont want them to stick out of the wheel well.
