Brake Lights Won't Shut Off
I'm sure it's the brake switch from reading most of the other posts with similar trouble. Does someone know what the brake switch looks like????
RE: Brake Lights Won't Shut Off
if i am not mistaken theres a stopper attached to your brake pedel which hits a button , sometimes they come loose or adjustment gets off just look up were your brake pedel is attached and you can see the switch mine has a cover so i assume yours does to you should see the switch once you remove the cover and from there you should know if your switch is working
| All times are GMT -4. The time now is 04:16 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
