DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   Dodge Neon (https://dodgeforum.com/forum/dodge-neon-6/)
-   -   What's the Difference? (https://dodgeforum.com/forum/dodge-neon/4221-whats-the-difference.html)
SXTNNY Apr 20, 2004 05:43 PM
So what is the difference in the 150hp R/T motor and the 132hp in my SXT? Where did Dodge get the extra ponies from??
techmanbd Apr 20, 2004 05:55 PM
RE: What's the Difference?
I have the sxt as well, but if I recall in my reading, is that one difference is we have the SOHC, Single Over Head Cam, and the magnum 2.0 has the DOHC Dual Over head cam
jrgong Apr 20, 2004 05:56 PM
well, i figure it was pretty easy.....
correct me if im wrong but pre-2000 neons had a base 130-sumthing horsepower, while the dohc pushed 150
that being said, they probably just looked back a few years to get the answer
keep in mind that the neon is an economy car...theres plenty that a big corporation can do to make it better...it just costs a little more
peace
jr.
71RoadRunner Apr 21, 2004 03:53 AM
The older SOHC's are 132 horsepower as well. The DOHC motors had the second cam, but less compression. The cam profile and intake manifold differences had a lot to do with it, as did the computer.
SXTNNY Apr 21, 2004 01:09 PM
OK, I didn't realize the R/T's had the DOHC. That answers all my questions then. Thanks.
LowSlowNeon Apr 21, 2004 04:45 PM
The new R/T's are not DOHC, they are SOHC just like a SXT. I'm not sure what creates the extra power on them, probably what roadrunner is referring to. The older R/T's were DOHC though, i believe all second gen neon (se, sxt, r/t) are single cam. Correct me if i'm wrong.
red91RT Apr 21, 2004 04:56 PM
If you want a good clue on the '00 and up 150 horse SOHC you just need look at the IT SOHC block available from mopar. Except for removing the smog you can get a lot with a cam, some machining and work in the intake.
You actually can get quite a bit from the intake and cam. . . .trust me on this. ;) My car still passes the CA sniffer check too.
SXTNNY Apr 22, 2004 12:50 PM
Ok...I thought the R/T was still using the single overhead cam. I checked a few places after and found that out. So it's most likely the computer, intake and exhaust, different cam profile, smog/emission crap? Well, that's not too bad. HAHA :)
01neonrt Apr 22, 2004 04:07 PM
the newer r/t are SOHC, but they have a better intake manifold, better header, and a better pcm. i think thats what creates more power.
pimpin97neon Apr 26, 2004 11:48 PM
click here that site could help you answer some more questions. It has a lot of info on the specs of the engines and trannys of the neons.
© 2026 MH Sub I, LLC dba Internet Brands
