DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   Dodge Neon (https://dodgeforum.com/forum/dodge-neon-6/)
-   -   Think these'll break? SWAY BAR MOUNT (https://dodgeforum.com/forum/dodge-neon/4835-think-thesell-break-sway-bar-mount.html)
red91RT May 10, 2004 09:22 PM
Finally, here's pictures of my sway bar mounts. Made from angle iron and barstock. Compare to original in the pics. About twice as thick material.
[IMG]local://upfiles/3297/Rp424018842.jpg[/IMG]
red91RT May 21, 2004 05:47 PM
RE: Think these'll break? SWAY BAR MOUNT
Holy s@#$!!! They did break! That's three different brackets I've broken on the car.
Okay. . . I admit. . . I drive the corners. . . HARD! But sheesh--I guess I better back off from the 22 MM bar to a 19 or even the 16. It's crazy.
71RoadRunner May 22, 2004 06:20 AM
Good God man!!!! I can drive a car pretty hard, but I haven't broken anything yet. You might be better off welding the bar straight to the car.[sm=smiley5.gif][sm=smiley36.gif]
red91RT May 27, 2004 07:40 PM
Solid welded suspension. Like a lawn mower. Could even put those little adjustable handles so I can raise or lower each corner according to my need.
Present plan is to reweld with two passes and then us a longer bolt through both barstock and plate and back up with a nut on the other side to help with clamping force to hold the two together.
. . . <sheepishly> Yes I drive VERY hard. When you drive a 150 miles a day you tend to look for things to keep you entertained. no tickets though.
71RoadRunner May 28, 2004 05:03 AM
No tickets though..... yet, you mean.[sm=smiley2.gif][sm=smiley36.gif]
© 2026 MH Sub I, LLC dba Internet Brands
