neon stuff
Does anyone know whereI can Get the white turn signal light for a 95 neon??What about the headlight seal????? </P> Also does anyone knowy I am using somuch oil consumption?????</P> |
neon stuff
ok heres the clear corners http://lightlens.com/dodge.htm</P> </P> Oil consumption could be a piston ring. Depends on all the symptoms. Anything else you can tell me? does it smoke? is the oil leaking anywhere?</P> |
neon stuff
Yes there is some blueish smoke , but not all the time. There is no oil spots anywhere on the ground and the engine looks to be normal.
neon stuff
hmmm blueish smoke indicates oil getting into the combustion chamber somehow. Have it checked out and diagnosed.
