Aux Power Ports
2 Attachment(s)
Thought it odd and very annoying that the Nitro's only have one aux power port. I fixed that today. Easy mod and well worth the effort. Appx eight dollars for the two plugs. Pulled the center panel and lower console panel for access. Cut the elastic strap going across the "map" pocket on the drivers side. This spot is perfect since it is recessed. Keeps the plugs from hitting your leg. I made sure to put them far enough forward so the seat would not interfere if you are short. I tied into the existing plug power and zip tied the wires for a neat finish.
