What size tires?? 35's or 37's?
Old Feb 26, 2009 | 01:34 PM
motoaggie's Avatar
motoaggie
Default What size tires?? 35's or 37's?
I recently put on a 5" skyjacker lift. I have 45" of clearance from the ground to the fender. I have 17" rims and also have a bully dog programmer. I am torn. Should I put on 35's or 37's?
thanks
Old Feb 26, 2009 | 03:28 PM
Bass Hunter's Avatar
Bass Hunter
It really depends on the look your going after. You can fit 35's with just a 2" level kit so they may look a little small with a 5" lift. That is unless you like that high in the sky look. Personally I'd go with the 37's and put some tire in those wheel wells.
Old Feb 26, 2009 | 03:38 PM
High_On_Diesel's Avatar
High_On_Diesel
I have 35's on my 06 2500 4x4. I installed a Kore 3" leveling on it and have 44 inches of clearance. Before I installed the kit I rubbed slightly on my upper radius arm. Seeing the clearance issue, you might rub with 37's. Whether or not that is an issue to you, I don't know. Just lettin ya know what I have encountered. With 35's I have a nice full look to the truck. Please let us know what ya come up with, please. Not to mention with that Kore the ride and handling is amazing!!
Old Feb 27, 2009 | 10:12 PM
Scott91370's Avatar
Scott91370
37's.
