blowing fuses on starter solenoid at start ?
I have 2000 dodge ram 2500 cummins , it as blown the starter solenoid fuse twice in 2 days ? What would cause this?
RE: blowing fuses on starter solenoid at start ?
you have a short somewhere. follow the starter cables and see if you can find a chaffed wire.
Will it was the starter , $150, to replace the starter 5 min to replace .[8D]
had the starter replaced two days ago and it worked great till today and blew two fuses, won't start
Fallow what drew said and check all cables to and from starter. If not starter. Check all wires on the solenoid end. To and from. Have you done anything to make any cable or wire shorter to where it rubs and may have warn a hole?
