Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
- Dodge Ram 2002-Present: How to Replace Ball Joints
Step by step intructions for the do-it-yourself repairs.
DIY Ball Joint Replacement
#52
IIRC the rotors are also floaters so yeah it should pretty much apply to the 1/2 ton. I had been suggested in this thread http://www.cumminsforum.com/forum/3r...ml#post2293965 that I used the press wrong and that may be why it bent.
Go about 1/2 way down and you'll see the changed pic of an alternate method...
#53
#54
#55
#56
#57
#58
Good article and pictures. I have the u-joint and ball joints on the RS of my 03 3500 QC to do. LS was done a few years back by shop, they gooned the hub, knuckle and broke all 4 bolts in the process, $1100 bill. Not this time.
We have done a couple of Ram 1500's and other than a few less bolts, its about the same deal. I found if I didn't have the press lined up straight with the ball joint then it was very difficult to press them in and out. Parts Source here has a press to borrow for free, and that is a good deal.
sprntpshr
sprntpshr
#59
sprntpshr
#60
Tried another set of OEM Dodge ball joints as I had heard mixed reviews on the Moogs. Have to remember this is a plow truck and I work the pants off of this thing.
This time I put Moog units in so we'll see what happens. If my pockets were deeper I would have had Carli but not this time. Maybe next round which is probably going to be next spring, haha.
I've heard of shops doing the hub/bearing everytime they do the ball joints or front u joints as they can't get the hub apart? Seems like an expensive way to change a ball or u joint.
