4x4 light that will not go out
Old 04-13-2011, 10:50 AM
Diesel Powerwagon's Avatar
Diesel Powerwagon
Diesel Powerwagon is offline
Default 4x4 light that will not go out
I swapped a 04.5 diesel 5.9 HO engine into an 05 powerwagon. I completely transfered all diesel wiring into the dash but the diesel had a push button transfer case that i swapped out with my manual 4 wheel drive shifter on the floor. No power is reaching the switch on the transfer case and i did swap out the wiring harness for the pushbutton 4 wheel drive with a diesel manaul 4 wheel drive harness. The transfer case is different in a powerwagon than a regular diesel because the 4 wheel drive switch is not compatable but both are a plunger type switch. This tells me that its an on off switch on both and supposedly the wire goes straight from the cluster where the light is lit to the switch and no where else. I tried a jumper wire to the swich and too a ground but that did not work to turn out the light.
Anyone have any suggestions?
Old 04-13-2011, 11:54 PM
olyelr's Avatar
olyelr
olyelr is offline
No (I suck at wiring). But I am salivating just thinking about your rig.
Theres a few wiring gurus on here that should be able to steering you in the right directional. Welcome to the site!
Old 04-14-2011, 09:43 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Welcome to the site. I will move this over to the CTD section so maybe some of those guys can help out. If you need any wiring diagrams then feel free to PM me
Old 04-20-2011, 03:53 PM
Diesel Powerwagon
Someone has tried to switch out a push button 4 wheel drive to a manual shifter on the floor. It is tens times better without the headaches of all the electronics.
Old 04-20-2011, 03:54 PM
Diesel Powerwagon
Nice truck by the way!
Old 04-20-2011, 03:56 PM
Diesel Powerwagon
I will probably have one of the first 8-12 inch air bag lifts on a diesel Powerwagon. I have but one issue, the 4 wheel drive light on the dash which i would love to make work but if i have too could pull the bulb.
Quick Reply: 4x4 light that will not go out
