TRANSMISSION OIL
Old 08-07-2007, 11:21 PM
atm's Avatar
atm
atm is offline
Default RE: TRANSMISSION OIL
what transaxle fuild due you guys recomend for a 95 dodge neon with a 5 speed manual transmission?
Old 08-08-2007, 12:03 AM
code's Avatar
code
code is offline
how do i find out which transmission i have? 01 5.9 turbo/excabautomatic longbed
Old 08-08-2007, 01:09 AM
dodgerules86's Avatar
dodgerules86
dodgerules86 is offline
Foratm's '95 Neon 5-speed manual, it should have Mopar Type MS-9417. Amsoil's Synthetic Manual Synchromesh
Transmission Fluid does meet this specification.
For code's'01 automatic, it gets ATF+4 (do not use Dexron or Mercon fluid, of course, Mobil 1 and Amsoil synthetics are useable)
Old 08-08-2007, 04:28 AM
kg1687's Avatar
kg1687
kg1687 is offline
I used penzoil senchromesh Not impressed shifting is tougher. Going to try either royal purple out or ams oil. probably ams oil. Easier to get ahold of. But Basically. Any high performance oil producer. Ams oil, Redline. Royal purple. All have stuff out there to use in your tranny. JUST BE SURE THAT IT" THE RIGHT STUFF! For instance don't use gear lube for manual tranny so on and so forth. Plus the dealers should be able to tell you what to use if you know what you have. But as for your sticker. They're correct as in don't use the wrong lube. But incorrect telling you who.... They would prefer you go to them and pay them.
Also Drew. Hey have you heard of anyone switching like a 03 5.9L with a NV5600 to a G56? Isn't it a similar set up? Gearing such and such? Or are they way different? Would it be worth considering if you tranny go **** up? Oh btw went to a site the other day stated taht the NV5600 brand new was only like 4k I expected more. It was a OEM Parts site so I dunno. [&:]
Quick Reply: TRANSMISSION OIL
