A/C top up
Hi,
I have a 1996 ram van, my a/c gas needs to be topped up, have seen the cans of refill but would like to know if its easy to do, have been told that i do not have to empty the gas first, is this correct.... |
If the system is working fine but low then adding a can is fairly easy to do. I would get one with the gage so you can see if it is low, correct, or over charged. Also be sure to use the sight glass while charging. Once the freon going through the sight glass goes from a foggy white to clear then it has sufficient charge. Also wear mechanics gloves to protect your hands while doing this for the can may get very cold as it charges up the system.
Thanks, the system is running fine appart from uphill, i have a slow leak so have to charge once a year, will have to have it frixed at one point ....Thanks for your help
irratic idle
When i turn on the a/c, after about 2 minutes the engine will start runing fast for about 30 seconds then back to normal. This does not happen with a/c off. T
he only thing i have done is about a week ago i topped up the a/c with its correct fluid. |
Originally Posted by Mobile Auto Repair
(Post 2216719)
Originally Posted by abouttime
(Post 2542204)
Originally Posted by alloro
(Post 2542246)
There is no sight glass.
Its a 3.9 tbi not carb as shown in pics is it in the same place
Those pics that Stev has posted is not of a carburetor, that "carburetor" looking thing is the throttle body which is the same on your 96 van. Your van is Sequential Fuel Injected being it is a Magnum Series engine.
Sorry just did not look closely, did not also realize that TBI is called Sequential Fuel Injected, thought that was multiport. Glad we have dodge forum..
