1994 b250 cruise control doesn't work
Hi,
as some of you may know, I have 1994 b250 (conversion van) 5.2
I had some problems with backfireing, but thanks God, afeter replacing fuel pump assembly everything is ok.
However I have another very annoying problem - cruise control doesn't work. Speed sensor is brand new and I can hear "click" from somewhere under the ac accumulator when I press the button on the steering wheel (engine bay, passenger side, below the ac) - but nothing happens - indication light doesn't light on and car slows down.
Fuse seems to be OK, vacuum lines around the engine itself are fine too - as far as I can tell - does anyone have diagram of cruise control harness and vacuum? Would be very grateful!
Horn is working fine!
Ok, so where to start?
Speaking slightly newer model. There should be a light indicating the speed control system is on. Find it next to the ON/OFF button on the lower left quadrant of the steering wheel. Set/Resume is on the lower right quadrant. There is no indicator lamp to show the system has engaged.
This is exactly the lamp on the steering wheel I am talking about - litlle green point - it doesn't work. Horn is working and there is this click I described above, but cruise control still doesn't work.
Can you tell me how to engage the cruise control? Maybe I do something wrong
Fuse is fine, and the system is powered - checked with multimeter. However, there is something strange about the cruise control buttons - I don't have neither the indicator light, nor the space for it!
Here's how the control unit of the cruise control looks like in my Van:
How to use it? Should I press on button while driving and then "set"?
