Alternator pulleys
Alternator pulleys
Hi all,
I pulled my alternator out to get it bench tested and found that the case has split over winter so it needs to be replaced. Can I buy a new alternator with a serpentine belt and put my double-v-belt pulley on it? There doesn't seem to be any name-brand double-v-belt 120 Amp alternators available for the 1991 Dodge B250 on Rock Auto. I want new and name brand so I don't mind changing the pulley if needed.
Cheers, Steve
Cheers, Steve
The pulley swap worked out. You can see that the measurement from the face of the pulley to the mounting boss is the same on both alternators. The old alternator was a reman by Wilson. The new alternator was a new Remy. Both were 120 Amps but as you can see the Remy comes with the wrong pulley.
