Vibration
Vibration
hi, have a 2001 DRV 3500 that vibrates/shimmeys slightly between 40 to 45.
Tire balance and alignment check good. This only happens when accelerating on flat or uphill grade. No vib. down hill on acceleration. Also if I back off gas (coast) between 40 and 45 no vibration (as in not tires). Replaced idler arms and lower ball joints with Moog parts a year ago with at least 5,000 mi. since with no vibration.
Any ideas would be greatly appreciated.
thanks
thanks
Yes about 7,000 mi. ago. I will check for play there though. I have recently been parking on a moderate grade and van would lurch a little from park to drive or reverse. After about 30 starts that way I now set the parking brake.
i forgot to mention in original post that one of my upper ball joints started "creeking" just a little bit so lubed both sides and noise stopped.
Thanks for your response
the vibration is slight and felt in the body (thru the seat) not the steering wheel. It feels exactly like out of balance front tire(s). Besides having balance rechecked good on fairly new (5,000 mi.) quality tires if I take my foot off the gas the vibe goes away instantly. Coasting at any speed will not cause vibe. The engine only has 86,000 mi. and runs smooth as could be. Tranny shifts smooth also.
out of balance front wheel transfer into the steering wheel. something transferred through the floor/seat can be rear tire, driveshaft, ujoint or pinion angle related. pinion angle changes when you accel/decel.
here is a cool app for diagnosis
https://www.youtube.com/watch?v=PT1nkmkdy5w
Thanks very much for everyone's help.
Trending Topics
