Ticking Noise From Doghouse? Valves?
Hoping someone can help me out. I was driving over the mountains here in Washington and used 'overdrive off' to climb a couple steep hills. My oil pressure light started flashing and I started hearing a ticking/clicking noise from what sounds like the doghouse. I had just checked my oil level and it was fine. I'm thinking maybe valve damage. I just got the van but it has 183,000 miles.
It's running fine now, but the oil light flashes at idle. Any idea what a top end rebuild would cost me vs buying a refurbished engine? I have a long drive home, so I hope this beast can make it. Thanks for any help. |
Verify if you actually have oil pressure issues before you spend a dime. No point doing a top end rebuild, if the bearings in the bottom end are shot. Put a mechanical gauge on it, and see what oil pressure is at idle, on a fully warmed engine.
(Post 3487486)
I also noticed a rattling coming from my catalytic converter today. Pretty sure it's toast. Definitely some exhaust leaks as I pressurized the system with a shop vac and sprayed soapy water down there. I couldn't find much in the way of instructions on how to replace it. I prefer everything DIY, but I've never worked on exhaust systems. Do you have any pointers? Thanks a lot for the direction. I'd really like to keep this van and would consider forking out some money for someone to do the engine if I can do some of the other things myself. Just on a tight budget. |
My catalytic converter was broken up and a chunk was lodged in the rear of the housing plugging my exhaust. The motor got progressively slower and lower on power until it hardly ran. They aren't cheap and mine was welded in the exhaust pipe. Junk yards cant sell used ones either where I am. It had no effect on oil pressure of course but It needs to be fixed. Sounds like you need a motor overhaul.
Oil pressure will tell the tale. If you really do have low pressure at idle, it's time for a rebuild. Nothing on the top end will really effect oil pressure.
(Post 3487514)
How hard are these engines to pull and rebuild? I have access to a tool library that will let me borrow a hoist and most tools. I could probably get my dad to help... I've never taken on an engine, but I'm fairly mechanically competent when I put myself to it and enjoy learning as much as I can about vehicles. Is it something I could take on myself? I see a lot of rebuild kits online for a pretty cheap. I see remanufactured engines for a few thousand bucks. How much would labor be on a rebuild? I do know a few shade tree mechanics who might be able to do it, but I have no idea how much a fair price would be for a rebuild. |
Generally.... A rebuild can cost as much, or more.... than simply buying an already remanufactured long block. And then there is the fun of finding a machine shop that can do the necessary work for you, in a reasonable amount of time.
Swapping engines is an exercise, but, don't really need any special tools to do it. Gotta disassemble a LOT of the front of the van to get it out/back in though. But, being a van, some of the most interesting parts are actually pretty easy, given the access you have to the engine/trans bolts. :) You and your dad could likely manage the swap in a weekend. |
(Post 3487565)
Swapping engines is an exercise, but, don't really need any special tools to do it. Gotta disassemble a LOT of the front of the van to get it out/back in though. But, being a van, some of the most interesting parts are actually pretty easy, given the access you have to the engine/trans bolts. :) You and your dad could likely manage the swap in a weekend. I found a remanufactured crate engine for $2500 plus tax and free shipping. The tranny has maybe 20k miles on it, so with a new engine and exhaust system, I should have a pretty solid van... haha. Thanks again! |
Heavier oil is just a bandaid fix. I don't recommend it on a van you want to put a lot of miles on. That's just asking for trouble. :D
(Post 3487628)
