Hey You, the PCV valve seems to be damaged. there is no spring load and the little piston/ball inside is falling around loose. it's a $4 item at the local store so i get that tomorrow morning. Thank you
yep, i found it today and was "disappointed" for it being so small. i will change it as well and then going after each hose. would you recommend the propane method to check where the leak is? thanks a lot for your help!!!
defrost is the default mode for the vacuum system, when you are at a higher rpm, if there is a leak, it will always default to the defrost setting, if you go through the vacuum lines and the check valves, you will be able to fix it,,,good luck,,,
