1984 dodge b150 van won't start
Old Dec 28, 2005 | 03:16 AM
tomtbarnes's Avatar
tomtbarnes
Default 1984 dodge b150 van won't start
Ok, I realize there are a lot of problems that could cause a vehicle not to start, but, I am not a mechanic. My van has 220,000 miles on it (slant-6 engine), but i have changed the oil every 2000-2500 miles. It acts like it wants to turn over, it feels like the starter is engaging, it has battery power--but it will not start. I last had it running about a week ago, and have driven it pretty regularly. I drive it for 3-4 days, and it sits for 2-3 days, only this time it has sat about 7 days. Any help, or suggestions will be appreciated. Thanks.
Old Dec 29, 2005 | 06:23 PM
stev's Avatar
stev
Default RE: 1984 dodge b150 van won't start
I'm in the same boat. It could be the Fuel Pump Relay.
https://dodgeforum.com/m_346270/tm.htm
If you find your relay, try switching it out with a "same value" relay that is not engine related. Turn the key and see if that works. Then the relay is the fault. These are under $10 at most auto stores.
My issue is, the relay isn't marked as Fuel Pump Relay and must be sharing that line with something else.
Stev
Old Dec 31, 2005 | 08:04 PM
Chump's Avatar
Chump
No fuel pump relay on an 84. You say the engine turns over and that it just won't start? Does it try to backfire through the carb? Has the ti8ming chain and gears ever been replaced?
