Will this intake manifold fit?
Looking to replace my intake manifold, but am really only seeing used ones on eBay. A few of the racing parts sites have some aftermarket ones and this is the cheapest one I found:
https://www.summitracing.com/parts/P...6/applications Will this fit my 1999 Dodge Ram can 1500 with 5.9L engine? When I go to “check the fit” the engine looks like it’s listed but I want to make sure I don’t have to fabricate brackets or cut too much stuff. Thanks all hope I make sense Intake mani |
If it has the horizontal intake manifold bolts it should fit. You will need an adaptor to put your stock throttle body on. I don't think anything of consequence bolts to the manifold. All the accessories bolt to the bracket that's bolted to the heads. You may need throttle cable brackets for the throttle body.
Does the intake have the provisions for the injectors?
Reading thru there, I don't think that's gonna work, that looks like its for the LA series engines. |
Never mind. It won’t fit. Probably just repair what I have with new gaskets and move on.
Thanks all. |
Yeah I forgot to mention the injector bosses.
