Weird event with my van.
Went to pick up some bags of wood pellets last night and the total weight was right at 1000lbs. Shortly after getting on the road back the engine would stutter and lose power and then run fine and then it just got worse until the engine died and I pulled off to the side of the road. All it would do was crank with no start. I suspected a fuel pump the way it was running. Got it towed back home and I unloaded the bags this morning. Went to see if I could hear the pump run and thought I heard it so I cranked it and it started right up and ran normally. The only thing changed was the weight in the back of the van. Does anyone have an idea of what may of happened. I'm at a loss.
I had just put gas in the tank when I left and I have no idea about the fuel pump. This was a cng van that was converted back to gas. The rear was squated an inch or two would be my guess.
The van was shut off while being loaded for appx. 15 mins and started acting up within 2 min of leaving and then was dead before 3 min.
Sake, when you said weird, I thought maybe you'd been involved in time or dimensional travel. How many miles on the van? What year and engine do you have? I have seen duel fuel equipment have fuel pump issues from the gasoline pump just sitting a lot. How was the fuel selector removed? Is the selector still in the van? Is the fuel pump relay good? Have you ever loaded it like this before? Is there any place underneath where a fuel line or wire may be displaced or compressed?
(Are you sure you didn't see any little Pixies or Gnomes when you were driving?)
Trending Topics
fwiw I would suspect the gas. Gas today sucks and I have seen a few times when I think I got 15-30% ethanol those times...other time I think it was water...
Just last week I got gas at Sams Club and my 2018 Colorado, which normally gets 20-21 got 16 with that gas. I ran it down to about 1/3 of a tank and put in regular Mobile and my mileage went back to 21.
I am also finding that since this summer was so hot that I had to run 89-93 octane to keep the engine from pulling too much timing...our vans were designed for real regular gas and they dont do well on any gasahol that is more than 10%...
