Missing Linkage on Blend / Recirculation Door
Hi all,
Working on a 2000 Dodge Ram Van 1500 with the 5.2L V8. I found an electric motor under the dash on the passenger side behind the glove box. It doesn't seem to be attached to anything. The white plastic arm moves when I turn the temperature control knob from hot to cold. And there's a disconnected metal rod nearby which runs through the firewall to the AC/Heat box under the hood. When I push this rod in, I get heat. When I pull it out, I get cold air (this might be reversed, sorry). Either way, I'm guessing the motor is supposed to push/pull that rod in and out. Has anyone got a photo of what the linkage between the motor and rod is supposed to look like? Looks like one could do it with duct tape, but as I've got it open, I'd like to do it right. And is this the blend door or the recirculation door that I'm moving? Thank you! https://cimg9.ibsrv.net/gimg/dodgefo...6ee5cfeb90.jpg |
Blend door is for temp.
Likely the only place you are going to find the part you need is a junkyard.... |
Or.... design it with a free 3D cad software and take it to a makerspace nearby to 3D print it?
Pay for shipping and I'd 3D print it for you just for fun. ;) |
The part you need is: Clip 4885297AA but it is discontinued. FWIW, it is #16 on the diagram shown here:
4885297AA - Genuine Mopar Clip (moparpartsgiant.com) |
Originally Posted by MKMcDonough
(Post 3581100)
Originally Posted by alloro
(Post 3581173)
Yeah, for freeware I've used Tinkercad online, but it is less than an intuitive software...
Tinkercad | Create 3D digital designs with online CAD |
Pick and pull would be my first place to try if they have a 98 and up van. You might also try googling that part number. Someone may have one somewhere nos. Stranger things have happened.
(Post 3581173)
Sorry all, I thought this was for Caravan, as that's the linkage diagram I need. My bad
