horn help
horn help
I got a set of these: http://www.jcwhitney.com/autoparts/S...&zmap=ZX128359
and I think that theyre supposted to go where the stock ones went. but is there a way how I can just splice the wires that go to the horn and add these in so when I "honk" both the stocks and these blow at the same time?
and I cant tell in the instructions but these just replace the stock wiring correct? the instructions are as good as a polock. no ofense to anyone that is
you might have to install the horn on its own circuit because if you hook it up to your stock horn wiring harness you will probably just kill your horns fuse.
