Dodge StealthThe car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
ok i fond out that a 92 doch will sawp into my 94 stealth. but will i have to change ecu or harness? also what parts are interchangable between a 92 dohc and a 94 sohc? Thanks!
I know the ECU will have to be swapped, but I am unsure about the harness. Engine wise, no, there are not really any parts that are interchaneable...the tranny should bolt up fine though.
ok but is there any difference in the mitsibishi engines and the stealh engines?? im almost possitive it will swap over fine but i just wanted to be sure. i just need a ecu and wire harnest correct?
