Wiring Aftermarket Amp.. Question?
Trying to install an aftermarket amp. Can anyone tell me which wire is positive and which is negative? Two black, one red with white stripe, one blue with white stripe. Doing this as you read. Please advise Asap!
Thanks. |
RE: Wiring Aftermarket Amp.. Question?
You really need a 12V test light.
the blue is the ground the black is the neg and the red is the pos.take the ground and find a bolt on the body to ground to (just clean it up and get metal to show). then just run the neg and pos from the battery.
