Dodge StealthThe car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
I have a 93 twin turbo, she runs fine for a while, then randomly the temp guage starts creeping up into the red. The thing is, the radiator and over flow are both lipping full. Once its hit the red all three times I have stoped almost immdiatly so I havent run it hot long, however it doesnt feel like its over heating as I drive it, I also check under the hood and it feels like its at a normal temerature. Is it possable that the gauge has gone wonky on me or that the water pump is randomly not pumping at only certain times? I have found no leaks what so ever and I am truely stumped.
Ive done some more reasearch and I am now 100% sure the problem is that my fans arent coming on. I can force them on with the AC though, I also already replaced the relay just in case. If you all think its the thermostat please tell me where it is and I will make with the changing.
had that problem in summer was the thermoastat feel bottom rad hose when car hot if hose is cold its thermastat ,not opening up 40 bucks your good to go 10 min job..
