mil codes for 1995 to 2000 JA body
Driveability
p-0106 barometric pressure out of range p-0107 map sensor voltage too low p-0108 map sensor voltage too high p-0112 intake air temperature sensor voltage low p-0113 intake air temperature sensor voltage high p-0117 ect sensor volt too low p-0118 ect sensor volt too high p-0121 tps voltage does not agree with map p-0122 throttle position sensor voltage low p-0123 throttle position sensor voltage high p-0125 closed loop temp not reached p-0131 o2 sensor 1/1 voltage short to ground p-0132 o2 sensor 1/1 short to voltage p-0133 1/1 o2s slow response p-0134 o2 sensor 1/1 stays at center p-0135 1/1 o2 sensor heater failure p-0137 1/2 o2 sensor volts shorted to ground p-0138 o2 sensor 1/2 short to voltage p-0140 1/2 o2 sensor stays at center p-0141 1/2 o2 sensor heater failure p-0171 1/1 fuel system lean p-0172 1/1 fuel system rich p-0201 injector #1 control circuit p-0202 injector #2 control circuit p-0203 injector #3 control circuit p-0204 injector #4 control circuit p-0205 injector #5 control circuit p-0206 injector #6 control circuit p-0300 multiple cylinder mis-fire p-0301 cylinder #1 mis-fire p-0302 cylinder #2 mis-fire p-0303 cylinder #3 mis-fire p-0304 cylinder #4 mis-fire p-0305 cylinder #5 mis-fire p-0306 cylinder #6 mis-fire p-0320 no crank reference signal at pcm p-0325 knock sensor circuit p-0340 no cam signal at pcm p-0351 ignition coil #1 primary circuit p-0352 ignition coil #2 primary circuit p-0401 egr system failure p-0403 egr solenoid circuit p-0420 1/1 catalyst converter efficiency p-0441 evap purge flow monitor failure p-0442 evap leak monitor small leak detected p-0455 evap leak monitor large leak detected p-0443 evap purge solenoid circuit p-0460 fuel level sending unit no change over miles p-0462 fuel level sending unit volts too low p-0463 fuel level sending unit volts too high p-0500 no vehicle speed sensor signal p-0505 idle air control motor circuits |
Page 2
P-0551 POWER STEERING SWITCH FAILURE P-0600 PCM FAILURE SPI COMMUNICATIONS P-0601 INTERNAL CONTROLLER FAILURE P-0645 A/C CLUTCH RELAY CIRCUIT P-0700 EATX CONTROLLER DTC PRESENT P-0703 BRAKE SWITCH STUCK PRESSED OR RELEASED P-1195 SLOW UPSTREAM O2S DURING CATALYST MONITOR P-1281 ENGINE IS COLD TOO LONG P-1282 FUEL PUMP RELAY CONTROL CIRCUIT P-1294 TARGET IDLE NOT REACHED P-1297 NO CHANGE IN MAP SENSOR FROM START TO RUN P-1299 VACUUM LEAK FOUND (IAC FULLY SEATED) P-1388 ASD RELAY CONTROL CIRCUIT P-1389 NO ASD RELAY OUTPUT VOLTAGE AT PCM P-1390 TIMING BELT SKIPPED 1 TOOTH OR MORE P-1391 INTERMITTENT LOSS OF CMP OR CKP P-1398 MIS-FIRE ADAPTIVE NUMERATOR AT LIMIT P-1486 EVAP LEAK MON PINCHED HOSE FOUND P-1489 HIGH SPEED FAN CONTROL RELAY CIRCUIT P-1490 LOW SPEED FAN CONTROL RELAY CIRCUIT P-1494 LEAK DETECTION PUMP SW OR MECH FAULT P-1495 LEAK DETECTION PUMP SOLENOID CIRCUIT P-1496 5-VOLT SUPPLY OUTPUT TOO LOW P-1598 A/C PRESSURE SENSOR VOLTAGE TOO HIGH P-1599 A/C PRESSURE SENSOR VOLTAGE TOO LOW P-1695 NO CCD MESSAGE FROM BODY CONTROL MODULE P-1696 PCM FAILURE EEPROM WRITE DENIED P-1697 PCM FAILURE SRI MILE NOT STORED P-1698 NO CCD MESSAGES FROM TCM P-1899 PARK/NEUTRAL SWITCH STUCK IN PARK OR GEAR |
P0120-throttle position signal
p0604-internal trans controller p0605-internal trans controller p0700-internal trans controller p0700-internal trans controller p0705-check shifter signal p0715-input speed sensor error p0720-output speed sensor error p0725-engine speed sensor circuit p0731-gear ratio error in 1st p0732-gear ratio error in 2nd |
Page 2
P0733-GEAR RATIO ERROR IN 3RD P0734-GEAR RATIO ERROR IN 4TH P0736-GEAR RATIO ERROR IN REVERSE P0740-TORQUE CONVERTER CLUTCH CONTROL CIRCUIT P0750-L-R SOLENOID CIRCUIT P0755-2-4 SOLENOID CIRCUIT P0760-OD SOLENOID CIRCUIT P0765-UD SOLENOID CIRCUIT P1716 - BUS COMMUNICATION WITH ENGINE MODULE P1738-HIGH TEMPERATURE OPERATION ACTIVATED P1739-POWER-UP AT SPEED P1765-SWITCHED BATTERY P1767-RELAY OUTPUT ALWAYS ON P1768-RELAY OUTPUT ALWAYS OFF P1775-SOLENOID SWITCH LATCHED IN TCC POSITION P1776-SOLENOID SWITCH LATCHED IN L-R POSITION P1781-OD PRESSURE SWITCH SENSE CIRCUIT P1782-2-4 PRESSURE SWITCH SENSE CIRCUIT P1784-L-R PRESSURE SWITCH CIRCUIT P1787-OD HYDRAULIC PRESSURE SWITCH CIRCUIT P1788-2-4 HYDRAULIC PRESSURE SWITCH CIRCUIT P1789-OD/2-4 HYDRAULIC PRESSURE SWITCH CIRCUIT P1790 - FAULT IMMEDIATELY AFTER SHIFT P1791-LOSS OF PRIME P1792-BATTERY WAS DISCONNECTED P1793-TRD LINK COMMUNICATION ERROR P1794-SENSOR GROUND ERROR P1795-INTERNAL TRANS CONTROLLER P1796 - AUTOSTICK INPUT CIRCUIT P1797 - MANUAL SHIFT OVERHEAT P1798-WORN OUT/BURNT TRANSAXLE FLUID P1799-CALCULATED OIL TEMPERATURE IN USE |
I have a 99 stratus es with auto stick, codes P0700, P0740, car runs good but is sluggish when shifting to drive from park and is limp sometimes, i switch car off and on and goes in gear normal
