mil codes for 2001 to 2006 JR body
P0031-o2 sensor 1/1 heater circuit low
p0037-o2 sensor 1/2 heater circuit low p0051-o2 sensor 2/1 heater circuit low p0057-o2 sensor 2/2 heater circuit low p0032-o2 sensor 1/1 heater circuit high p0038-o2 sensor 1/2 heater circuit high p0052-o2 sensor 2/1 heater circuit high p0058-o2 sensor 2/2 heater circuit high p0068-manifold pressure/throttle position correlation p0071-ambient temp sensor performance p0072-ambient temp sensor low p0073-ambient temp sensor high p0107-map sensor low p0108-map sensor high p0111-intake air temperature sensor performance p0112-intake air temperature sensor low p0113-intake air temperature sensor high p0116-engine coolant temperature performance p0117-engine coolant temperature sensor low p0118-engine coolant temperature sensor high p0122-throttle position sensor #1 low p0123-throttle position sensor #1 high p0125-insufficient coolant temp for closed-loop fuel control p0128-thermostat rationality p0129-barometric pressure out-of-range low p0131-o2 sensor 1/1 voltage low p0137-o2 sensor 1/2 voltage low p0151-o2 sensor 2/1 voltage low p0157-o2 sensor 2/2 voltage low p0132-o2 sensor 1/1 voltage high p0138-o2 sensor 1/2 voltage high p0152-o2 sensor 2/1 voltage high p0158-o2 sensor 2/2 voltage high p0133-o2 sensor 1/1 slow response p0139-o2 sensor 1/2 slow response p0153-o2 sensor 2/1 slow response p0159-o2 sensor 2/2 slow response p0135-o2 sensor 1/1 heater performance p0141-o2 sensor 1/2 heater perfromance p0155-o2 sensor 2/1 heater performance p0161-o2 sensor 2/2 heater performance p0171-fuel system 1/1 lean p0174-fuel system 2/1 lean p0172-fuel system 1/1 rich p0175-fuel system 2/1 rich p0201-fuel injector #1 p0202-fuel injector #2 p0203-fuel injector #3 p0204-fuel injector #4 p0205-fuel injector #5 p0206-fuel injector #6 p0300-multiple cylinder misfire p0301-cylinder #1 misfire |
Table of contents
p0302-cylinder #2 misfire p0303-cylinder #3 misfire p0304-cylinder #4 misfire p0305-cylinder #5 misfire p0306-cylinder #6 misfire p0315-no crank sensor learned p0325-knock sensor #1 circuit p0335-crankshaft position sensor circuit p0339-crankshaft position sensor intermittent p0340-camshaft position sensor circuit p0344-camshaft position sensor intermittent p0401 - egr system performance p0403 - egr control circuit p0404 - egr position sensor performance p0405 - egr position sensor low p0406 - egr position sensor high p0420-catalytic 1/1 efficiency p0430-catalyst 2/1 efficiency p0440-general evap system failure p0441-evap purge system performance p0443-evap purge solenoid circuit p0452-nvld pressure switch sense circuit low p0453-nvld pressure switch sense circuit high p0455-evap system large leak p0456-evap system small leak p0457-loose fuel cap p0461-fuel level sensor #1 performance p0462-fuel level sensor #1 low p0463-fuel level sensor #1 high p0480-low speed fan control relay circuit p0481-high speed fan control relay circuit p0498-nvld canister vent valve solenoid circuit low p0499-nvld canister vent valve solenoid circuit high p0501-vehicle speed sensor #1 performance (auto trans) p0501-vehicle speed sensor #1 performance (manual trans) p0506-idle speed low performance p0507-idle speed high performance p0508-iac valve sense circuit low p0509-iac valve sense circuit high p0513-invalid skim key p0532-a/c pressure sensor low p0533-a/c pressure sensor high p0551-power steering switch performance p0562-battery voltage low p0563-battery voltage high p0572-brake switch #1 circuit low p0573-brake switch #1 circuit high p0580-speed control switch #1 low p0581-speed control switch #1 high p0582-speed control vacuum solenoid circuit p0586-speed control vent solenoid circuit p0594-speed control servo power circuit p0600-serial communication link |
TABLE OF CONTENTS - Continued
P0601-INTERNAL MEMORY CHECKSUM INVALID P0622-GENERATOR FIELD CONTROL CIRCUIT P0627-FUEL PUMP RELAY CIRCUIT P0630-VIN NOT PROGRAMMED IN PCM P0632-ODOMETER NOT PROGRAMMED IN PCM P0633-SKIM KEY NOT PROGRAMMED IN PCM P0645-A/C CLUTCH RELAY CIRCUIT P0685-ASD RELAY CONTROL CIRCUIT P0688-ASD RELAY SENSE CIRCUIT LOW P0700-TRANSMISSION CONTROL SYSTEM/READ TRANSMISSION DTCS ON THE DRBIIIT P0850-PARK/NEUTRAL SWITCH PERFORMANCE P1115-GENERAL TEMP SENSOR PERFORMANCE P1404-EGR POSITION SENSOR RATIONALUTY CLOSED P1593-SPEED CONTROL SWITCH STUCK P1602-PCM NOT PROGRAMMED P1603-PCM INTERNAL DUAL-PORT RAM COMMUNICATION P1604-PCM INTERNAL DUAL-PORT RAM READ/WRITE INTEGRITY FAILURE P1607-PCM INTERNAL SHUTDOWN TIMER RATIONALITY P1696-EEPROM MEMORY WRITE DENIED/INVALID P1697-EMR (SRI) MILEAGE NOT STORED P2074-MANIFOLD PRESSURE/THROTTLE POSITION CORRELATION - HIGH FLOW/VACUUM LEAK P2096-DOWN STREAM FUEL SYSTEM 1/2 LEAN P2097-DOWN STREAM FUEL SYSTEM 1/2 RICH P2098-DOWN STREAM FUEL SYSTEM 2/2 LEAN P2099-DOWN STREAM FUEL SYSTEM 2/2 RICH P2302-IGNITION COIL #1 SECONDARY CIRCUIT-INSUFFICIENT IONIZATION (2.4L) P2305-IGNITION COIL #2 SECONDARY CIRCUIT-INSUFFICIENT IONIZATION (2.4L) P2302-IGNITION COIL #1 SECONDARY CIRCUIT-INSUFFICIENT IONIZATION (2.7L) P2305-IGNITION COIL #2 SECONDARY CIRCUIT - INSUFFICIENT IONIZATION (2.7L) P2308-IGNITION COIL #3 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION (2.7L) P2311-IGNITION COIL #4 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION (2.7L) P2314-IGNITION COIL #5 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION (2.7L) P2317-IGNITION COIL #6 SECONDARY CIRCUIT- INSUFFICIENT IONIZATION (2.7L) P2503-CHARGING SYSTEM VOLTAGE LOW P2610-PCM INTERNAL SHUTDOWN TIMER FAST RATIONALITY |
Instrument Cluster
I'm trying to delete this posts, but cannot figure out how.
