06 stratus thermostat housing
I need to replace my thermostat housing on my 06 stratus. It seems fairly simple but I can't for the life of me seem to find a step by step walk through of exactly how to go about handling this. Does anyone know of a link or can help me out with this? It'd be greatly appreciated. Thanks
Welcome to DF
You didn't state which engine you have, But i will move your post the Stratus section. Here is some information on the 2.7 engine. 1. Disconnect negative cable from remote jumper terminal. WARNING: Do not remove pressure cap or any hose with the system hot and under pressure because serious burns from coolant can occur. 2. Drain cooling system . 3. Raise vehicle on hoist. 4. Remove right front wheel and belt splash shield. 5. Remove accessory drive belts . 6. Remove lower generator mounting bolt. 7. Lower vehicle. 8. Disconnect generator electrical connectors. 9. Disconnect AC clutch and AC pressure sensor electrical connectors. Reposition wiring harness. 10. Remove oil dipstick and tube. Plug hole in oil pan where dipstick tube mounts with water tight stopper. WARNING: If hole for dipstick tube in oil pan is not plugged, coolant will enter oil pan. Serious engine damage can occur. 11. Remove remaining generator mounting bolts. Remove generator. 12. Disconnect hoses at thermostat housing. 13. Remove thermostat housing bolts. 14. Remove thermostat and housing. |
