No heat
No heat
I have a Dodge Stratus 2000. It is only blowing cold air when the heat is turned on. I was told it was the blend actuator, however once the mechanic got in to replace that he said the blend door was broken and needed to be replaced. It have called part stores and none have a part called the blend door.
Sonic concerned it wasn't the actuator, or maybe the broken part just isn't called the blend door. I don't want to put a ton of money into this car. Any help is appreciated.
